Hi Matt, KMotionCNC accepts G90 and G91 but not G90.1 or G91.1. The I J center point must always be relative. Regards TK
Message: 7645 |
Date: 6/9/2013 |
Subject: Re: end of arc differs ij mode issue |
i tryed both G90 and G91 in the G code with no change at all on the kmotion error.
Message: 7646 |
Date: 6/9/2013 |
Hi Matt,
That is because G90 and G91 do not effect the I J mode. KMotionCNC only accepts arc I J in relative mode. You must change your GCode to be I J Relative mode. I'd be surprised if your CAD system can not do this.
Message: 7648 |
Date: 6/9/2013 |
interesting
this is what i use on the pro level....
http://www.dolphincadcamusa.com/
the help tabs in both the cad and cam show nothing about "relative"
could this be because the post processor outputs something in the code kmotion does not like?
thanks matt
> Hi Matt,
> From: yeamans115 <yeamans115@...>
> Sent: Sunday, June 9, 2013 10:57 AM
> Subject: [DynoMotion] Re: end of arc differs ij mode issue
Message: 7649 |
Date: 6/9/2013 |
Hi Matt,
I Googled for you and found this:
http://www.cnczone.com/forums/dolphin_cadcam/82846-post_partmaster_mach3.html#post625684
Looks like to change I J from absolute to incremental change lines in the Dolphin CAM post processor from:
#I = { $XCEN:XARC } #J = { $YCEN:YARC }
to
#I = { $XCEN-$OLDX:XARC } #J = { $YCEN-$OLDY:YARC }
Message: 7651 |
Date: 6/9/2013 |
great! i will look into that asap.
i guess this means all my codes i use have to go through the cam again with the right post processor?
> Hi Matt,
> Â Â Â #I =Â Â Â Â {Â $XCEN:XARC }
> Â Â Â #J =Â Â Â Â {Â $YCEN:YARC }
> to
> Â Â Â #I =Â Â Â Â {Â $XCEN-$OLDX:XARC }
> Â Â Â #J =Â Â Â Â {Â $YCEN-$OLDY:YARC }
> Sent: Sunday, June 9, 2013 1:50 PM
> interesting
> thanks matt
> > Hi Matt,
> > That is because G90 and G91 do not effect the I J mode.ÃÂ KMotionCNC only accepts arc I J in relative mode.ÃÂ You must change your GCode to be I J Relative mode.ÃÂ I'd be surprised if your CAD system can not do this.
> > From: yeamans115 <yeamans115@>
> > ÃÂ
Message: 7662 |
Date: 6/14/2013 |
nice, now to see about customizing it a little.
thanks
> Hi Matt,
> to
> interesting
> thanks matt
> > Hi Matt,
> > ÃÂ
Message: 11797 |
Date: 6/27/2015 |
I’m a little confused about G91.1. It appears G91.1 is the incremental (relative) mode for I, J, & K offsets that is suppose to be used with KMotion. However it appears that G90.1 is an absolute mode for I, J, & K offsets that shouldn’t be used with KMotion. Is this correct?
Andy
Message: 11798 |
Date: 6/27/2015 |
I'm a little confused concerning G91.1. It appears that G91.1 is in fact the incremental (relative) mode for I, J, & K offsets that is suppose to be used with KMotion. However G90.1 appears to be an absolute mode for I & J offsets and shouldn't be used with KMotion. Is this correct?
Andy
Message: 11804 |
Date: 6/27/2015 |
Hi Andy,
KMotionCNC only supports Incremental I J K mode for arc centers. Those GCodes for switching modes are not supported or allowed.
HTH Regards TK
Message: 11819 |
Date: 6/28/2015 |
I understand that KMotion currently throws out an error if your Gcode includes G90.1 or G91.1, although would it be safe to assume that G91.1 is the correct mode to be in? Regardless of whether or not KMotion supports the ability to switch between absolute and incremental modes for arc centers?
Andy | | | | | | | | | |
